01-25-2022 11:49 PM
I installed nidaqmx driver for USB 6001 on ubuntu. When I try to communicate with the device, it gives me the error below:
nidaqmx.errors.DaqError: Device identifier is invalid.
Device Specified: Dev1
Is USB 6001 compatible with ubuntu?
Thanks!
01-26-2022 11:45 AM
According to this: NI Hardware and Operating System Compatibility - NI, USB-6001 is not supported on Linux.
01-27-2022 11:10 AM
Thank you Jerry. Can you recommend a DAQ device that will work well on Linux?
01-27-2022 04:14 PM
Depends on what your budget and IO need is, unfortunately none of NI's low cost USB DAQ devices are supported on Linux. The only USB DAQ I believe that it is supported on Linux is CompactDAQ, cDAQ-9171/9174/9178. It is highly versatile with a great set of IO modules, but it is much more expensive than an USB-6001.
