11-15-2015 12:24 AM - edited 11-15-2015 12:40 AM
There are two card that I installed on this computer. The two cards are PCI-MIO-16E-4 & PCI-6713. They both have cable connecting to each other on the top. The Current OS is Windows 7 64bit with 4GB of memory. I went to NI drivers Support and typed in the serial number for those two cards. Both card came back with the same drivers. Which is NI-DAQmx Base 15.0. Installed the NI-DAQmx Base 15.0, but the device manager is still showing exclamation mark on those two cards. So, I tried scan for new hardware and got a message saying driver unable to install. I also tried reboot. Please help.
hms168
Solved! Go to Solution.
11-15-2015 09:42 AM
11-16-2015 11:35 AM
Drivers install successfully. Thank You!
