Multifunction DAQ
Installed NI-DAQmx Base 15.0 for (PCI-MIO-16E-4 & PCI 6713) device manager is still showing exclamation mark on those two cards.
There are two card that I installed on this computer. The two cards are PCI-MIO-16E-4 & PCI-6713. They both have cable connecting to each other on the top. The Current OS is Windows 7 64bit with 4GB of memory.  I went to NI drivers Support and typed in the serial number for those two cards. Both card came back with the same drivers. Which is NI-DAQmx Base 15.0. Installed the NI-DAQmx Base 15.0, but  the device manager is still showing exclamation mark on those two cards. So, I tried scan for new hardware and got a message saying driver unable to install. I also tried reboot. Please help.
hms168
(3,629 Views)
I don't understand how you got linked to DAQmx Base. Unless you need compatibility to Linux or Mac, you should be installing the normal DAQmx.
http://www.ni.com/download/ni-daqmx-15.1.1/5665/en/
(3,614 Views)
Accepted by topic author hms168
Drivers install successfully. Thank You!
(3,590 Views)
