Yesterday I downloaded Nidaq69.exe (48.6 MB installation file) together
with
LV6Eng.Exe (24.3 MB) ? LabView English Installation components. After
download
I could not complete the installation successfully. During installation
following error had occurred: ?Error 1311 Source file not found.
D:\National Instrument\NI-DAQ\CABS\daqlv60eng.cab
Verify that the file exists and that you can access it?
Because of this I also have problem during Win98 start up. The message on
Windows startup:
?Can not find a device file that may be needed to start a Window
application.
The Window registry or SYSTEM.INI file refers to this device file, but the
device file no longer exists.
Nissm32k.drv
Press any key to continue?
Please suggest suitable solution.
NI Software : DAQ
Version : NI-DAQ 6.9.0
OS : Windows 98
NI Hardware : N/A
Drivers : N/A
Other Hardware/Instruments : N/A
CPU : Pentium
RAM : 128
Vendor : Compaq - Armada E500
Customer Information :
RAMACHANDRAN vENKAT
BIMETAL BEARINGS LIMITED
IN
ramv48@vsnl.net
Ph: (91-4344) 60941
