Multifunction DAQ
Install error 2349 in DAQmx v9.9
I have trouble in installing DAQmx v9.9.0 onto WIndows Embedded standard 32bit.
Error 2349 (... MIO Device Driver 2.12.0 ...) occurs during instrallation.
I had solved this problem onece before, by sellecting this device driver setup program alone.
But this time, I forgot and could not find the setup program.
For my application reason, I would like to use v9.9.
Plase anyone could help.
(3,379 Views)
Accepted by topic author kn
Sometimes, we can force the install through this error.  When that doesn't work, the recommendation would be to remove DAQmx entirely from the system to eliminate any package conflicts that could be interfering with the installation, then try installing again.  Hope this helps.
(3,317 Views)
Thanks for reply, and sorry it took for such long time.
(1,571 Views)
