Multifunction DAQ
Input Signal for cDAQ9189
Hello! I am working on connecting Pressure Transducers to the cDAQ9189. I have the option to purchase pressure transducer with output of: 4-20mA, 0-5V, 1-5V, 0-10V, RS485. For some reason, I can't seem to find the documentation on the accepted (or preferred) input signal onto cDAQ9189. Any help would be appreciated - thanks.
(1,726 Views)
cDAQ-9189 is just a chassis. You need modules to connect your input signal.
Learn more about CompactDAQ Systems
(1,718 Views)
Hello, the module we plan on using is NI 9205 with DSUB. Looking at the back of it, the specs are as follows:
32-Ch +-10V to +-200mV 16-Bit Analog Input
+-10V Ch-to-COM
60VDC CAT | Ch-to-Earth Isolation
Does that mean I should go with the 0-10V output signal Pressure Transducer?
Thank you
(1,426 Views)
Yes, 0-10V sensor is more suitable for NI-9205
(1,399 Views)
