Multifunction DAQ
Increasing Available Disk Space in the NI cDAQ 9133
Hello! I am facing some problems regarding C Drive space issue in NI cDAQ 9133. The buil-in disk space is around 16GB and after installing windows 7 OS, NI Max, NI LabView softwares, there's nothing left to save the acquired data.
Is there any way to connect cDAQ 9133 with my Computer HDD like the cDAQ 9178? Or, any other way to increase the disk space?
(2,386 Views)
As described in the User Manual, you can use a USB device as a hard disk drive. For that, you need to go to the USB Configuration Submenu, instructions for which you can find in the user manual.
(2,322 Views)
