Multifunction DAQ
Incompatibility or a bug in using the counter
I have a BNC 2120 DAQ. I have been trying to use one of the example VIs, namely Count Digita Events,  for counting. I am using the quadrature encoder provided in the DAQ to test it. It works fine as long as the count directions are set for 'Count Up' or 'Count Down'; however, does not work for 'Externally Controlled' , it simply goes to a large number and stays there whether I rotate the quadrature controller knob clockwise or counterclockwise. I am using LabVIEW 2009. I was wondering if it is a bug.
(2,928 Views)
Howdy airydisk!
What DAQ device are you using with the BNC 2120?
Also, please describe exactly what connections you have made with you encoder to the BNC 2120.  Thanks!
Barron
Applications Engineering
(2,891 Views)
