Multifunction DAQ
In Document ID: 2S9D4L2O, how do you set the regeneration option to ON?
I have a VI that works ok on 1 computer, but errors out on another. I'm using a PCI-6025E card in both machines.
(2,698 Views)
Greetings,
If you are using Traditional NI-DAQ or version 6.9.x you will use the "Allow Regeneration" input terminal of AO Write.vi. If you are using DAQmx then you will have to use the DAQmx Write Property Node.
Justin Britten
APplications Engineer
(2,698 Views)
