04-11-2005 08:47 AM
04-13-2005 04:03 AM
04-13-2005 05:09 AM
04-13-2005 10:21 AM
04-13-2005 10:30 AM
04-14-2005 05:25 PM
04-15-2005 02:39 AM
07-26-2006 05:11 AM
Hi reddog!
I don't know if you still using this forum, but i have a question to ask you:
I want to synchronize differents cards (PXI-6254, PXI-6225 and PXI6123) with a 10 MHz Clock. I don't have any problem with the M Series card (6254 and 6225) cause they are able to retrieve the 10MHzRefClock from the PXI bus. I can't use this signal as a Timing source. My problem is the S Serie 6123 does not have this possibility. You cannot access to the 10MHzRefClock...
So i tryed to route the 10MHzRefClock to the TriggerLine 7 using a serie M board, and the use the TriggerLine7 for the Timing source . The problem is i get the error : "89136 :Specified route cannot be satisfied, because the hardware does not support it". So what can i do to synchronize all my boards together using an external 10MHz clock ????
07-27-2006
12:51 AM
- last edited on
04-16-2025
03:44 PM
by
Content Cleaner
what you need to do is to make your 6123 the master board in your system. It has to be delivering the clock to the other boards you need to synchronize.
Unfortunately the 6123 can't phase lock to the PXI_10MHz clock. This feature is only available for the 6115 and 6120 among S Series Boards.
But what you really can do, is to input an external clock on the 6123 (or use its internal time base) as described in the S Series User Manual under Analog Input>>Analog Input Timing Signals>>AI Sample Clock Signal. Then you just need to route this clock over to RTSI7 or PXI_Trig7 Line (same stuff). The other 2 boards are going to receive their clock from the same RTSI or PXI_Trig line.
This takes care of sharing the clock. Then you probably want to trigger the acquistion on the 2 slave boards with a pulse coming from the 6123. This pulse could just be the AI Start Trigger which is issued by the 6123 when the acquisition starts.
This will be your scenario, having the same clock for the boards, and having them synch'ed with a dig pulse.
You can look at some examples that are available in LV Example Finder under HW Input & Output>>DAQmx>>Synchronization>>Multidevice
AlessioD
