06-26-2024 01:26 AM
Hi.
I use .Net c# and usb-6001.
I want to use the AO increse without timer.
How can i use it?
example:
06-26-2024 09:07 AM
You can use the hardware-timed analog output feature to generate an array of ramp signals.
This hardware-timed technique is the right way to guarantee you the ramp rate as long as the external device doesn't load the signal beyond the drive capability.
