‎01-05-2010 07:40 PM
‎01-05-2010 08:47 PM
‎01-06-2010 10:52 AM
Thanks for any help anyone can provide!
‎01-06-2010 10:59 AM
I don't remember offhand what the +5 output current of the DAQ board is. I've always used an external supply. A simple wall transformer that you can pick up at places such as Radio Shack works fine. You might be able to use the DAQ card but that would depend on the number of drivers being used and the current required for each relay
The relay drivers are available as inverting and non-inverting outputs. Typically, you just connect a digital output to one of the inputs and the output is connected to the relay.
