Multifunction DAQ
I use a SCXI 1000DC box multiplixed on the channel zero of a DAQPad-6020E. How should I tune gain, polarity and voltage range of my zero channel to digitize the 32 analog input of my SCXI box ?
Please give me an anwser in Lab Widows CVI (I don't want to use Measurement and Automation Explorer).
(2,294 Views)
You will need to configure the SCXI system using MAX. You will follow different steps depending on which SCXI modules you have. This page is a good starting point:
http://www.ni.com/support/scxi/scxidaq/content.htm
Once you have configured the SCXI modules, you can reference them inside CVI using a DAQ channel name that looks like this:
ob0!sc1!md1!0
where "sc1!" is the SCXI chassis, "md1" is the module # in the chassis, and "0" is the channel on that module.
(2,294 Views)
