Multifunction DAQ
I try to build executable programs for CF6004, a lot of missing VI or C files
Hi Angelo, my solution was very easy. I simply changed OS from German Win2000 to English WinXP, and it’s work. I believe that problem is hided in incompatibility of regional and language options, but it’s not that simple because suggestions on page http://digital.ni.com/public.nsf/websearch/4027C3B3A8E4A49186256EBE007F1B72?OpenDocument not help completely. May be you’ll find better solution, good luck.
Taras.
Message 11 of 12
(783 Views)
Hello everybody,
i have the same problem with errors in Vi´s after build executable in labview 7.1 with pda device.
This is because regional and language options must change. Go to Tools->Options-> Frontpanel -> and remove the tick from "use local decimal point".
Close labview and start new and then the errors are away when you build executable/running vi in pocket device.
Message 12 of 12
(758 Views)
