Boxer,
I checked your example and have several easy but important suggestions for you:
1.- First, make sure that the first time you initialize the VI, the AI Config and AI Start are executed, because based on the debug I made, your program doesn't do it, and this is very important.
2.- Add an AI Clear after the acquisition is done, so that you release the resources. This is a good programming technique, and may help you solve your issue.
3.- Add an Error Cluster, so that you know if an error occurred at some point of the acquisition. This will help you track the issue.
4.- What do you mean by "the acquisition is not good". What does it happen? What does it do? Do you get an error? <- This is the reason of step 3.
5.- Finally, if you have doubts
programming AI, check one of the shipping examples of LV. They can give you a much clearer idea.
Hope this helps,
L Aguila
Applications Engineeer
