Multifunction DAQ
I have a problem with componentworks and delphi 5.0 using a 6711 analog out card. The card outputs the same waveform on all the channels.
I have followed the examples and created a 2d array which plots perfectly on the graph but when the same array is passed to the card, only 1 row of the array
is outputted on every channel.
(2,113 Views)
I would try to interleave the data in a 1-D array.
So now you would have
array element 0 = first point on first channel
array element 1 = first point on second channel
array element 2 = second point on first channel
array element 3 = second point on second channel
(2,113 Views)
