ent studio. I need to output 8 channels of data----I have found that the shortest latency to execute the output of the data using AOGeneratewaveforms or WFM_OP is 7 msec. This long lag is not tolerable in my application. Is there any way to reduce this?WFM_Op is a high-level function that combines configuration and output into one function. I would suggest breaking up your configuration and generation steps to reduce the latency that you're seeing. NI-DAQ ships with analog output examples that demonstrate how to incorporate the low-level functions into your application.
Erin
