07-30-2008 06:09 PM
07-31-2008 07:27 AM
Hello erb174,
If you use the "Save to ASCII/LVM Express VI" function to save the signal into an LVM file, Signal Express will generate an error message according to the description you reported (the file is of "Incorrect file type"). This is a known bug and it will be fixed in the next version of the software. You can temporarily solve the problem by doing a Save to ASCII (text file) instead in LV. Save to LVM actually works in SE, so we're defering for now.
07-31-2008 07:53 AM
07-31-2008 08:08 AM
05-04-2009 06:47 AM - edited 05-04-2009 06:47 AM
Hi EB,
I just had the same problem on my machine:
I am using LabVIEW 8.6 and wrote some example values to a LVM-File. I tried to import this file into SignalExpress 3.0 and got the error "invalid file type".
Well, I took a closer look (using Notepad.exe from Windows) into the LVM-File and compared it to a generated by SignalExpress one. Examining the header, I found out, that LabVIEW 8.6 is using the "WRITER_VERSION 2" and "READER_VERSION 2", but SignalExpress uses 0.93 and 1.
So there was a major change in LabVIEW 8.6 in writing LVM-Files. I manually changed the reader version from 2 to 1 in line 3 of the LVM-File:
Afterwards, SignalExpress did successfully import the modified LVM-File.
Be careful using this workaround, because SignalExpress could misinterprete the data in the file due to the major version change of the LVM-format.
Best regards from Germany
05-04-2009 08:43 AM - edited 05-04-2009 08:44 AM
The difference between version 1 and version 2 is the addition of the Decimal Separator field. This properly supports local standards by using either a period "." or comma "," for the decimal indicator. This version of LVM was introduced in LabVIEW 8.6. As MarianMO said, it is relatively easy to manually convert a version 2 file to version 1. Do the following:
01-19-2010 08:09 AM
I seem to be having the same issue but unfortunately your work-around doesn't seem to be working for me. I don't suppose you have any other ideas?
Cheers,
Andy
01-20-2010 07:33 AM
Apologies, for reasons know best to the LabVIEW gremlins, your work-around has now started working. I have no idea what that was about...
Andy
