Multifunction DAQ
I am using the PCI-6110E/6111E with the NI-DAQ software version6.7.Is there a way to record at the same time analog and digital channels?If,ye
s can I have timestamps for each sample?I mean,is there a notion of time information on this board?Finally,is there a way to know ,in the double buffer's case,the number of samples in the halfbuffer which is not full if the acquisition stops by a trigger?.I am using the PCI-6110E/6111E with the NI-DAQ software version6.7.Is there a way to record at the same time analog and digital channels?If,yes can I have timestamps for each sample?I mean,is there a notion of time information on this board?Finally,is there a way to know ,in the double buffer's case,the number of samples in the halfbuffer which is not full if the acquisition
Thank you for your interest in advance
(3,091 Views)
s can I have timestamps for each sample?I mean,is there a notion of time information on this board?Finally,is there a way to know ,in the double buffer's case,the number of samples in the halfbuffer which is not full if the acquisition stops by a trigger?.PALE wrote:
Start by looking around the examples that ship with LabVIEW (if you are
using LabVIEW).
Also look around zone.ni.com for general data acquisition information &
examples. A good site.
Mark
(3,091 Views)
s can I have timestamps for each sample?I mean,is there a notion of time information on this board?Finally,is there a way to know ,in the double buffer's case,the number of samples in the halfbuffer which is not full if the acquisition stops by a trigger?.Pale;
That board of yours only have the capability of doing static digital I/O. By static, I mean that the update of the digital lines will be done by a Software call, and not by hardware; fact that make the synchronization of the analog inputs with the digital lines not possible to be done with that board only. To have that operation accomplished, you will need to have a PCI-DIO-32HS board, and syncrhonize that board together with the 6110 board of yours by using the RTSI bus.
The half buffer of the NI-DAQ function calls is not accessable by address, meaning that the answer to your next question is no.
Hope this helps.
Filipe
(3,091 Views)
s can I have timestamps for each sample?I mean,is there a notion of time information on this board?Finally,is there a way to know ,in the double buffer's case,the number of samples in the halfbuffer which is not full if the acquisition stops by a trigger?.This answer can be used for all questions posted in this discussion forum. It is of no use unless the question asked for it. Thanks but no thanks. We need answers that have some time of knowledgeable input to the real question.
(3,091 Views)
s can I have timestamps for each sample?I mean,is there a notion of time information on this board?Finally,is there a way to know ,in the double buffer's case,the number of samples in the halfbuffer which is not full if the acquisition stops by a trigger?.This answer can be used for all questions posted in this discussion forum. It is of no use unless the question asked for it. Thanks but no thanks. We need answers that have some type of knowledgeable input to the real question.
(3,091 Views)
