Multifunction DAQ
I am measuring temperature using SCXI-1100 chasis', SCXI-1102 modules, TBX-1303 terminal blocks and K type thermocouples. I have a meter
that measures current through the device under test, and provides an output. Can I run that current measurement to the TBX-1303 terminal block and set up a channel to read it, eventhough the remaining channels on the TBX-1303 are set up for thermocouples?
(2,513 Views)
that measures current through the device under test, and provides an output. Can I run that current measurement to the TBX-1303 terminal block and set up a channel to read it, eventhough the remaining channels on the TBX-1303 are set up for thermocouples?You can use the SCXI process-current resistor pack to convert individual channels to measure current rather than voltage. Since the resistors are installed on a per-channel basis, there should be no problem using the unmodified channels for thermocouple measurements.
The SCXI-1102 User Manual describes where to install the process-current resistors for each channel.
(2,513 Views)
that measures current through the device under test, and provides an output. Can I run that current measurement to the TBX-1303 terminal block and set up a channel to read it, eventhough the remaining channels on the TBX-1303 are set up for thermocouples?The SCXI resistor pack is precision 249 ohm resistors, so you can use a 249 ohm resistor if you want.
Mark
(2,513 Views)
