Timmy,
Your best solution is to use a PCI-6110 simultaneous sampling board which can sample each channel at a rate up to 5 MS/s.
If you are using the PXI platform, you can use the PXI-6115 which can sample each channel up to 10 MS/s simultaneously.
Both of these boards can be found in the National Instruments catalog available online at www.ni.com
