Howto use NIDAQmx with mingw gcc 3.4.2
Hi, I'm trying to use nidaqmx (8.5) under QT(5.1.1). The MultVoltUpdates-IntClk example under Labwindows works correctly, the equivalent example compiled in QT is compiled and linked correctly without errors, but when I start it, I don't see any waveform on the output.
Someone knows a solution?
Message 11 of 11
(996 Views)
