01-12-2006 09:18 AM
01-12-2006 09:31 AM
01-12-2006 09:51 AM
01-12-2006 10:09 AM
Actually, what it looks like to me is that if I want to use an SCB-68 to get at the other inputs, I can't use the pre-configured signal conditioning pads on the SCB-68 circuit board.... I just have to do my own thing 😞
By using the SCB-68 (and signal conditioning pads) to wire inputs inputs 16 to 31 in differential mode with a bias resistor tied to AIGND... I end up having to sacrifice a bunch of other inputs.
01-13-2006 10:18 AM
01-13-2006 10:39 AM
Hi All-
If you would also like a Quick Reference Label for the second connector of your PCI-6225, check out this KB for a .pdf download.
Hopefully this helps-
