I am new to labview. In my application, I have two select lines based on which sensors are selected. Inorder to select particular sensor I have to output 5v to digital output lines. How can I do that?? I have tried sending the boolean True or False to the digital outputs. But it dnt work.
Yeah, I have tested it in MAX. If i just input the boolean then its not working. I have taken the screen shot of my code. I am using DAQ assistant to generate digital output for every 1000secs.
