Multifunction DAQ
How to use all analog outputs with NI PCIe-6323
Hi there,
I'm using the PCIe-6232 card together with a connector block (SCB-68A). Right now my LabView code provides two analog outputs, however, I want to add a third one. In principle, I can use 4 analog outputs based on the card specifications, but the connector block only has 2. Do I need a second connector block if I want only another analog output?
Thanks for your help!
(195 Views)
Refer to Figure 8 of this document, it shows all four AO's available through Connector 1:
http://www.ni.com/pdf/manuals/371805b.pdf
EDIT: Now I am confused the pinouts here only show 2 AO's per Connectors:
http://www.ni.com/documentation/en/multifunction-io-device/latest/pcie-6323/pinout/
Probably need another SCB-68 then...
-AK2DM
(163 Views)
Accepted by topic author marius246
I think you may be misreading that figure.  It clearly only shows AO2 and AO3 available through Connector 1.  AO0 and AO1 are available through connector 0 per Figure 2.
In other words, yes, you need a second cable and connector block to access the other two AOs.
(124 Views)
croohcifer:
Yes a definite misread on my part, thanks for re-checking.
-AK2DM
(118 Views)
Highlighted
Ok, then that's how it is. Thank you very much for your answer!
(101 Views)
