‎06-04-2024 05:09 AM
Hi, i need help with this:
As you can see in the image, I have already synchronized NI-9361 with NI-9237 (I am not sure this is correct but i am getting synchronized reading in the tdms file), and I want to synchronize NI-9219 module with these two modules. I have tried the same method which I used to sync NI-9361 but it's not working. Can anyone help me with how to synchronize three devices simultaneously?
Kumaresan
‎06-04-2024 07:12 AM
As long as all the modules are in the same cDAQ chassis, you can use Easily Synchronize and Trigger NI-DAQmx with Channel Expansion
‎06-06-2024 05:52 AM
Thanks for the information.
Kumaresan
