How to read the current value of a digital output line on a NI-DAQ in C#
NI-USB-6xxx
C#
Is it possible to read the current output value from a digital output line ?
i.e after setting the putput high, i would like to confirm the high state via my c# code.
I don't want to use a analog input to do it.
(5,892 Views)
This is Gajan an Applications Engineer, could you be a bit more specific in regards of what you are trying to achieve please.
Thanks.
(5,838 Views)
I would like to read the current state of a digital output line. Is it high or is it low ?
(5,831 Views)
There is a KnowledgeBase that describes similar query: http://digital.ni.com/public.nsf/allkb/CB86B3B174763C3E86256FFD007A2511
Could I also know how you are planning to measure the current.
(5,794 Views)
Use the same tak to read the value of the channel
using (Task digitalWriteTask = new Task())
                    //  Create an Digital Output channel and name it.
                    digitalWriteTask.DOChannels.CreateChannel("Dev1/po​rt0", "port0",
                        ChannelLineGrouping.OneChannelForAllLines);
                    //  Write digital port data. WriteDigitalSingChanSingSampPort writes a single sample
                    //  of digital data on demand, so no timeout is necessary.
                    DigitalSingleChannelWriter writer = new DigitalSingleChannelWriter(digitalWriteTask.Stream​);
                    writer.WriteSingleSamplePort(true, (UInt16)this.numericEdit1.Value  );
                    //  Create the reader
                    DigitalSingleChannelReader reader = new DigitalSingleChannelReader(digitalWriteTask.Stream​);
                    //   Read back the value
                    this.textBox1.Text =  reader.ReadSingleSamplePortByte().ToString();
 Curt
(5,766 Views)
