You probably do not want to use a traditional waveform. LabVIEW has a Waveform Chart which inputs one point at a time. Waveform Graph inputs an array.
I suspect that the data is stored in an array. You need to read the arrays in and build them into larger arrays. If your right click on the build array vi, you can select concantenate which will append one array to the end of the other. When you have built your giant array, just feed it to a waveform graph.
If you need to see some example code, go to the advanced search page. It is at www.ni.com >> support >> advanced search (it is at the botton--click on the words). Enter excel read in the all the words field and search just the example programs. There were for hits.
Jeremy Braden
National Ins
truments
