You should be able to convert the voltage to the pressure. It's generally a linear transformation, but you'll have to check the datasheet for your specific device to make sure of this. All you need to do is apply that scaling to the voltage input that you get, and you'll know the pressure.
C. Weeks
Product Support Engineer
NI
