Multifunction DAQ
How to output 3 synchronized AO using 2 6036E cards.
Hello out there,
I am trying to output 3 offset waveforms using 2 pci cards (a 6259 and a 6036E).  If I run parallel tasks I have timing issues, but cannot figure out how to appropriately trigger the task on the secondary card to start such that the waveforms are aligned (waveform timing is used for the clock).  Any help or examples whould be appreciated.
-Stefan Kienle
(2,996 Views)
Hello Stefan,
Here is an example that shows how to synchronize analog output across 2 DAQ cards.  This example requires the two boards to be connected by a RTSI cable (to share the timing signals).
Hope this helps!
Justin M.
(2,983 Views)
