Ben on 7/25/2002 answered:
"Hi its me again.
Can you see the ringing with a scope?
What exactly are you using to get the counts from the board?
Are you sure you are re-setting the counter and have the clock configed to come from your external signal?
Ben
Hi Ben,
Thanks for your help on this. I have tried using both Labview software and NI Measurement and Automation test panels. I remember trying to figure out how to address the counter correctly using Labview "Counter Start", "Counter Read", "Counter Stop" VI's. Perhaps you could confirm for me, I am putting the signal from the preamp into "Source 1" on the A/D connector board, and I use "GPCTR1" to identify the counter.
Does the "Counter Stop" VI reset the counter? I was as
suming it does. If not, how do I do that?
But, using the NI Measurement and Automation test panels, selecting "Simple event counting" and "GPCTR1" I see lots (100,000's) of counts pile up in 1 second when I should only see 5-10.
I haven't checked with a scope (we don't have one in our lab!) but I may try to borrow one to confirm it is ringing.
My basic set up is as follows:
BNC (50 Ohm) from preamp TTL out to BNC T adapter with a 50 Ohm Terminator cap.
Signal lead from BNC plug to PIN 41 (Source1) of AT-MIO-16 I/O connector. Ground lead to PIN 24 (DIG GND) which is also grounded to be the same as that of the preamp and dectector.
Thanks again for your help,
Joel
