Oops! I misspoke. I found this VI in the NI Developer Zone, not the Discussion Forum. The link to that VI is: http://zone.ni.com/devzone/cda/epd/p/id/4414 If you go to this link, you will find a library file: 4643.llb The VI that I am trying to adopt is within this library file.
I understand that this VI is written specifically for M series boards, but I am just wondering if I can modify this VI and use it with my 6062E card. So first, I tried to run this VI --- trying to see what is not compatible with my E card. As expected, an error message pops up.
The error message contains the following information:
Error -200077 occurred at Property Node DAQmx Timing (arg 1) in DAQmx Timing (Sample Clock).vi
Possible reason(s): Requested value is not a supported value for this property.
Property: sampTimingType
You Have Requested: Sample Clock
You Can Select: On Demand
Task Name: _unnamedTask<0>
This is the place that I realized my 6062E card only supports "On Demand" software-timed DIO, but not "correlated" hardware-timed DIO. I don't know if I am right, but that's the impression I got out from the above-mentioned error message.
I apologize for my ignorance in Labview, but I am new in this field, and I really want to know if I can output AO and digital signals simultaneously using my 6062E card. If so, how? Modifying this VI seems a solution to me. So I tried. But I had problems. Maybe the best solution is to purchase a M series card or any card that can do hardware-timed DIO, but this solution does not seem realistic to me --- due to budget issues. Any suggestions???? Maybe I am tied with my 6062E card, . It is simply not possible. I don't know, but I would appreciate any comments or suggestions.
Sincerely,
Fuh
