Multifunction DAQ
How to lock phase of analog input with USB6009
I'm trying to figure out if its possible to lock the phase of analog input with a USB6009. I'm using the C++ API and the example files. I'm running a basic 50Hz sine wave into USB6009 and reading in values with the "Cont Acq-Int Clk" example. When I printf the first value - data[0] - the value will slowly drift. I'm not exactly certain how to lock onto this signal. Is this a triggering issue? I know the USB6009 doesn't have an analog trigger mode. Does anyone have any ideas?
Thanks and best regards,
Matt
(2,629 Views)
Matt,
You are correct that the USB 6009 does not support analog triggering.  If you could output a square wave that was phase locked to the sine wave, you could use that as a digital trigger on PFI 1.
-Christina
(2,604 Views)
