Multifunction DAQ
How to lock a DAQ card/board serial number to a particular program?
Is there any way to "tie" a DAQ card serial number to a Labview design/program?
For example, PCI-6601 has a serial number 12345, and I write a program (called ProgramABCD) to do data acquisition, I like to "tie"/"bind" the 12345 and ProgramABCD together, so that ProgramABCD will not work on another PCI-6601 (unless I change the matching serial number in ProgramABCD to the new PCI-6601).
Thanks.
(4,534 Views)
Accepted by lize
Hi Lize,
You could programmatically read the serial number of the device using a property node and then based on that, decide whether to end or continue the program.
However, if this is going to be distributed to the end user as a .VI file not an executable then the end user could always go into the code and change/modify it so he can use different devices with it.
Notes for Branch AE:
Please reply to This Post within 24 hours
The US AE is expected to reply to all of your posts within 24 hours. Having this expectation will keep the escalation moving quickly and toward a fast resolution.
You can also use other communication channels: Phone, Skype, etc. to discuss the issue with the US AE. This can help with troubleshooting and quick diagnosis of the issue.
Click here to provide kudos for a post on this page
(4,514 Views)
Understood. Thanks for your quick response.
(4,505 Views)
Modifying a VI and building a new exe for each DAQ card seems like a disaster waiting to happen. For LabVIEW, have you seen the licensing toolkit?
(4,495 Views)
No, I don't know the third-party licensing. I'll take a look. Appreciated the information.
(4,489 Views)
