09-11-2019 07:52 AM - edited 09-11-2019 08:01 AM
My computer version is windows10 (64 bits), and I install labview2018 64 bits, NI MAX 18.0.
I want to know the file directory of nicaiu.dll which nidaqmx-python uses. (Because I want to know which dll I used in my code, lib64 version or lib32 version. )
Maybe in C:\Program Files (x86)\National Instruments\Shared\ExternalCompilerSupport\C\lib64\msvc or C:\Program Files (x86)\National Instruments\Shared\ExternalCompilerSupport\C\lib32\msvc or D:\Program Files (x86)\National Instruments\Shared\ExternalCompilerSupport\C\lib64\msvc ?
So how can I get it?
print(sys.version)
returns:
3.6.9 |Anaconda, Inc.| (default, Jul 30 2019, 14:00:49) [MSC v.1915 64 bit (AMD64)]
Solved! Go to Solution.
09-18-2019 04:05 AM
The file that you are looking for is located in C:\Windows\System32 for 32-bit and C:\Windows\SysWOW64 for 64-bit systems respectively.
Thank you.
