Hi, and thanks for your responses.
My application is that i am repeatedly applying a square wave light stimulus to a slice of retina tissue. I vary the intensity of the light via PWM. In some instances, the stimulus goes from dark to a set intensity and then back to dark, and in others, there is a "background" illumination that is stepped up or down. FSK was ideal for this. Why won't NIDAQmx support FSK, and is it in the plan for the future? With NIDAQmx 7.4, i can do hardware timing of single pulses from a counter, but i need PWM of 1kHz pulses, and i don't know that software can be reliable at that rate. I tried the PWM-counter example on a friend's maching running labview 7.1, and it started missing clock cycles at 1 kHz.
I use Borland C++ Builder for my apps. I would appreciate any advice you can give.
Brady
