I am using two NI PCI-6254 DAQ boards with LabVIEW and NI-DAQmx in a data-logging application that reads 64 analog input channels and writes them to files on my hard drive. I have noticed that the data type of the output of the Analog Sample NChan NSamp VI is an 8-byte floating point (DBL) type. I understand this to result from the VI converting the raw ADC counts produced by the ADCs on the DAQ board into real numbers that fit the input range I had earlier specified. I would really rather LabVIEW skip the conversion step and just give me the raw ADC counts. That way, the processor has less work to do and I can store only 2 bytes per sample rather than 8 bytes per sample. (I will be generating a ton of data in my application and would like to keep log files as small as possible.) Is there an easy way to turn off the automatic scaling feature in LabVIEW and have the Analog Sample VI just give me data of a 16-bit unsigned integer (INT16) tpye?
And on a related note, I am a little confused on what LabVIEW exactly does when it scales the ADC values into a real number range with units of volts. Earlier today, I generated a 20Hz sine wave with amplitude 1.4V on Dev1/ai0 and tried to record 5 seconds worth of measurements of it. I set the input high and low levels to +2V and -2V in LabVIEW using one of the NI-DAQmx VI's and recorded the DBL values that were generated. When I read my data samples, each they read like:
