Multifunction DAQ
How to flip the Y-axis of the square wave
Hello Everyone,
I want to reverse my square wave, I mean the x-axis should same but only amplitude is reverse, when the original waveform is at a high level then reverse waveform is at a low level and vice versa.
(1,371 Views)
Use negate (-x)
(1,340 Views)
Dear Member,
Thank you so much for your response, I got your answer, but I have 0 to 5 Volt amplitude square wave and I want to flip my Y axis such as within o to 5 volt but states should be changed from HIGH to LOW and LOW to HIGH.
(1,338 Views)
