04-18-2019 08:07 AM
Hello Everyone,
I want to reverse my square wave, I mean the x-axis should same but only amplitude is reverse, when the original waveform is at a high level then reverse waveform is at a low level and vice versa.
04-21-2019 09:02 PM
Use negate (-x)
04-21-2019 09:26 PM
Dear Member,
Thank you so much for your response, I got your answer, but I have 0 to 5 Volt amplitude square wave and I want to flip my Y axis such as within o to 5 volt but states should be changed from HIGH to LOW and LOW to HIGH.
