Multifunction DAQ
How to fine tune 24VAC for SCXI-1160 1324
Good day,
I'm searching to fine tune the 24VAC (which is now suprisingly 28VAC).
We are using NI-PCI-6030E, SCXI-1001 chassis with 1160 & 1324.
In code (vi), I see that just a relay is switched to power our module to test (wanted 24VAC).
SC1Mod4/ch0 or 1.
I assume that I have to define the 24VAC with Measurement & auotmation explorer? NI-488.2 interactive control? or NI-DAQmx Configuration tool?
I'm new in this stuff and have to maintenance an old system..
best regards,
koen.
(4,473 Views)
Accepted by topic author kdCMC
I don't understand your question about 24VAC. The scxi module is a simple relay board and the 6030 cannot generate that high of a voltage. You need to look at the schematics of your system to see what is being used for a voltage source.
(4,465 Views)
yeh, right, that's what I assumed afterwards yesterday evening.
I thought: we give the NI tower 220V supply, so, there is intelligence to supply other voltage levels... 🙂
sorry
(4,454 Views)
