‎09-05-2022 02:44 AM
I want to connect the NI PCI-6221 card (Sub-D front connection, ref: 779418-01) to the NI BNC-2090A interface (ref: 779556-01). If I am right, the SHC68-68-EPM cable allows to connect a PCI-6221 with the BNC-2090A, but only the card with a VHDCI front connection (ref: 779066-01).
Is it possible to connect the Sub-D type card on the BNC-2090A?
Thank you.
David
‎09-05-2022 11:46 AM
Unfortunately no, you cannot connect the PCI-6221 with a 37-pin D connector with the BNC accessory
These are the supported accessories as per this article
‎09-06-2022 02:34 AM
That's what I feared...
Thank you for your help.
David
