How to connect NI PCI-6221 Sub-D to NI BNC-2090A?
I want to connect the NI PCI-6221 card (Sub-D front connection, ref: 779418-01) to the NI BNC-2090A interface (ref: 779556-01). If I am right, the SHC68-68-EPM cable allows to connect a PCI-6221 with the BNC-2090A, but only the card with a VHDCI front connection (ref: 779066-01).
Is it possible to connect the Sub-D type card on the BNC-2090A?
Thank you.
David
(1,931 Views)
Accepted by topic author david.thura
Unfortunately no, you cannot connect the PCI-6221 with a 37-pin D connector with the BNC accessory
These are the supported accessories as per this article
Santhosh
Soliton Technologies
Only two ways to appreciate someone who spent their free time to reply/answer your question - give them Kudos or mark their reply as the answer/solution
(1,907 Views)
That's what I feared...
Thank you for your help.
David
(1,896 Views)
