Multifunction DAQ
How to bring PXI 6133 to retriggerable mode (analog in)
i've a analog signal, which should be sampled (finite sampled, trigger).
On other cards i used the "start.retriggerable" node  - what works great, an i get all the signals
--> the PXI 6133 doesn't know this command  😞  , so i loose about 30% of my data
What can i do ? Has anyone a idea
geatings
(3,385 Views)
Hello Bernysberny1,
you might be able to use the Start.Retriggerable Property not on the Analog Imput Sample Clock but instead on a Counter Output Task.
The Counter Output Task generates a finite Number of Samples every time the Trigger Condition is met.
The Counter Output is then used as a Sample Clock for a Continous Analog Imput Task.
I hope this helps a bit!
Best Regards!
Moritz M.
(3,377 Views)
