Hi all,
Iam working with PCI-6723 32 channels analog output,iam generating a square wave,sampling at 100ks/s.
ican able to generate upto 10kHz square wave.The wave form appears clean when it is below 1000Hz if i crossed 5KHz to 7KHz, iam getting jitter in the output square wave form,i have experimented with the digital filter but still the jitter is persisting,
since iam using 12 channels for such similar generations so i have fixed the sampling rate.100Ks/s.
kindly suggest me how to avoid this jitter in high frequency generation.
OS::WINDOWS 2000
HARDWARE PCI-6723.
I/O :SCB 68
NIDAQ:7.3
LABVIEW 7.1
kindly find the attached file.
Thanks and Regards
RAJESH
