07-10-2014 10:34 AM
Hi All,
I am pretty newbie to Labview. I just wanted to know how do I add phase information to the existing waveform module as shown in the DaQmx Voltage- Continuous output example.
Seee attached, I figured that the the 'Output array' is actually a preset control, is there anyway I may add the phase as an additional parameters to that?
Thank you in advance for any help.
Eric
Solved! Go to Solution.
07-11-2014 08:02 AM
If you press ctrl+H, the Context Help Window opens and you can hover over the Function Generator VI to see its Inputs/Outputs as well as navigate to its detailed help. As you can see from this screenshot, there is an output for the phase which is separate from the waveform output.
