08-08-2006 11:32 AM
08-09-2006 07:54 AM
You can work with the NI-ELVIS like as if you have a 68pin connector block, except that on the ELVIS protoryping board are only six analog inputs are available.
So you only have to wire your signals to this AI (upper left of ELVIS board) and do a simple signal acquisition which could be find within the following library:
..\National Instruments\LabVIEWx.x\examples\Analog in\Measure Voltage.llb
Regards, Christian
