According to NI documents, NI-4351 is capable of scanning single channel at 60 Hz. It is critical for my application to have high sampling rate.
Initially I have NI-DAQ v 6.9 and also the NI-4351 driver. I could only get ~10 Hz (9.7 Hz exactly) reading rate for single channel. I tried in VB/C++ using either my codes or sample codes from NI. I tried to set up NI-4351 without accessary (via MAX) so there will be no "auto-zero" nor "CJC" attempted. I also tried the VisualBanch-Logger. It too gave me only ~10 Hz scan.
After contacting tech support, I was told 60Hz is not supported by NI-DAQ v6.9, so I unintalled everything and installed v 6.8.1.
This helps to bring the scan rate to
60 Hz in VisualBench-Logger for single channel, but I still could not achieve 60 Hz with C++/VB using the driver functions.
Anyone has similiar experience?
