Multifunction DAQ
How to Use Two SCB-68As & a PCI-6259 to process more than 16 Differential Inputs
I've got  Two SCB-68As & a PCI-6259 connected to my Windows 7 32 Bit PC running Matlab R2014a.
If I try and run the following Matlab script :
s= daq.createSession('ni');
ch1 = addAnalogOutputChannel(s,'dev1', 'ao0', 'Voltage');
ch2 = addAnalogOutputChannel(s,'dev1', 'ao1', 'Voltage');
ch3 = addAnalogOutputChannel(s,'dev1', 'ao2', 'Voltage');
ch4 = addAnalogOutputChannel(s,'dev1', 'ao3', 'Voltage');
in1 = addAnalogInputChannel(s,'dev1', 'ai0', 'Voltage');
in1.InputType='Differential'
in2 = addAnalogInputChannel(s,'dev1', 'ai1', 'Voltage');
in2.InputType='Differential'
in3 = addAnalogInputChannel(s,'dev1', 'ai2', 'Voltage');
in3.InputType='Differential'
in4 = addAnalogInputChannel(s,'dev1', 'ai3', 'Voltage');
in4.InputType='Differential'
in5 = addAnalogInputChannel(s,'dev1', 'ai4', 'Voltage');
in5.InputType='Differential'
in6 = addAnalogInputChannel(s,'dev1', 'ai5', 'Voltage');
in6.InputType='Differential'
in7 = addAnalogInputChannel(s,'dev1', 'ai6', 'Voltage');
in7.InputType='Differential'
in8 = addAnalogInputChannel(s,'dev1', 'ai7', 'Voltage');
in8.InputType='Differential'
in9 = addAnalogInputChannel(s,'dev1', 'ai8', 'Voltage');
in9.InputType='Differential'
in10 = addAnalogInputChannel(s,'dev1', 'ai9', 'Voltage');
in10.InputType='Differential'
in11 = addAnalogInputChannel(s,'dev1', 'ai10', 'Voltage');
in11.InputType='Differential'
in12 = addAnalogInputChannel(s,'dev1', 'ai11', 'Voltage');
in12.InputType='Differential'
it fails on :
Is there some switch setting which I need on the second SCB-68A so that I can contiue my addAnalogInputChannels so that they are active and working as Differential InputTypes on the second SCB-68A ?
Rob
(4,462 Views)
Rob,
Have you read the manual? Table 3-1 of the M Series User Manual specifies the input pairs for differential channels:
For differential measurements, AI 0 and AI 8 are the positive
and negative inputs of differential analog input channel 0.
Similarly, the following signal pairs also form differential
input channels:
<AI 1, AI 9>, <AI 2, AI 10>, <AI 3, AI 11>, <AI 4, AI 12>,
<AI 5, AI 13>, <AI 6, AI 14>, <AI 7, AI 15>,
<AI 16, AI 24>, <AI 17, AI 25>, <AI 18, AI 26>,
<AI 19, AI 27>, <AI 20, AI 28>, <AI 21, AI 29>,
<AI 22, AI 30>, <AI 23, AI 31>
Lynn
(4,458 Views)
