Hello.
I am using a 6216 AOM board and I currently need to generate a 50 kHz signal for an external AOM, and this has been no problem.
However, I also need to be able to SEE and USE this signal in my VI
(for example, to be able to view the signal in a graph, and more
importantly, to be able to use the signal as an input for a software
based Lock-In Amplifier).
How can I do this?
I've been reading about routing signals and I believe I can do this,
however, the routing does not solve the problem that I need to be able
to see and use the signal inside my software.
Please help!
Sincerely
JSL
