I m programming a VI that generates a waveform, which is applied in a sensor, and get the output signal of this sensor when the input has gotten a specific value during a defined period. I m using LABVIEW 7 and a LABPC + DAQ board, with a NI daq 6.9.3. I had looked for information about synchronization but I didn�t find examples of VIs that uses it.
Can someone suggest solutions for this?
Thank you in advance.
Juliana
